what are the following commands in CATIA V5 Freestyle : hightlight lines Analysis and reflection lines , I NEED obvious answer
The Highlight Line Analysis tool is used to check surfaces for smoothness. Any curvature discontinuities will visually standout. The Reflection Line tool is another tool for similar purposes, but uses a different technique to measure the surface. Both are described in the CATIA documentation, although not a lot of information on the theory.
