What is a draft analysis tool in SW and what is it used for?
Draft is "Taper" on parts. Taper on part is for release from mold. Draft analysis will help determine if you do have taper (draft). Is it positive or negative and what degree (draft angle). Positive or negative will help you determine where parting line and or shutoff will be. See answer to your previous questions about parting lines, parting surfaces and shutoffs.
