Whats the best way to details threads for holes on drawings?
I use hole wizard
Draw new sketch with hole locations
Define size to your requirements
Select face for holes (will place 1st hole here)
Place additional holes as required
Edit hole wizard sketch and delete first hole and relocate others if required
You can also add holes with additional points if desired
