2nd tutorial on how to model a wide-chord fan for a turbofan engine in CATIA
**** Steps 16 thru 35. *****
16. Make 2 more intersection points.
17. Create the shape shown, following similar procedure as the one before.
18. Make the profile shown on the zx-axis. The left-most point should be coincident with the H-axis. The right-most point should be coincident with the V-axis.
19. Make the line shown.
20. Make a Revolution Surface with both the profile and line you made earlier. The command for it is underneath the Extrude command.
21. Create a multisection surface. Make sure the closing points are correct.
22. Create another circle on the yz-plane.
23. Extrude the circle.
24. Split the fan blade and extruded circle. Click Other Side if the wrong part is cut out.
25. Fill in the tip of the blade.
Step 11:
26. Make the following spiral on the yz-plane.
Step 12:
27. Enter sketcher on the yz-plane and project the spiral, then offset it and close the ends.
Step 13:
28. Project the spiral sketch onto the spinner cone.
Step 14:
29. Extrude the projection.
Step 15:
30. Split the extrusion and spinner.
Step 16:
31. Fill in the empty space using the spinner as the Support.
Step 17:
32. Join the fan blade and its filled-in tip.
Step 18:
33. Create the rest of the blades by using Circular Pattern.
Step 19:
34. You are done! Go ahead and render it and admire your work.
35. If you have any questions, feel free to ask either on here or as a private message.
