2S Petrol engine case using Catia
This tutorial is about how to model a 2S petrol engine case using Catia V5. This tutorial consists step by step procedure.
  1. Step 1: Creating an engine case
    Open Catia V5 and click Start > Mechanical Design > Sketcher.
    Create sketch as shown below with given dimensions of 20 X 40 mm by selecting a plane and then click OK.
    Exit from the sketcher environment by clicking the exit workbench icon.
  5. Step 5:
    Click on the pad option and extrude the selected sketch up to 3.5 mm.
  6. Step 6:
    Select the face marked and click Reference elements > Plane.
    Create a Datum plane as shown above by entering the offset distance of 3 mm.
  7. Step 7:
    Create the sketch as shown below in the newly created DTM1 plane and click OK.
  8. Step 8:
    Pad (Extrude) the Circle created in previous step to the depth value of 25.5 mm.
  9. Step 9:
    Select the top face of the rectangle and create sketch as shown below with specified dimensions and click OK.
    Note: Use references tools in Profile group to make it simple.
  10. Step 10:
    Pad the previous created sketch with extrude depth value of 25 mm.
  11. Step 11:
    Select the face shown below and create a sketch with specified dimensions and click OK.
  12. Step 12:
    Create a pad as shown below with extrude depth of 14 mm.
  13. Step 13:
    Create sketch below with specified dimension by selecting the face as selected below.
  14. Step 14:
    Pad the sketch created in previous step with depth value of 6 mm.
  15. Step 15:
    Create fillets as shown below by selecting the edges with radius of 2 mm and click OK.
    Create another fillet on the edge selected before with radius of 1 mm.
  16. Step 16:
    Create the sketch as shown below by selecting the mid plane with specified dimensions.
    Note: Use Oriented Rectangle at 70 degrees from the axis with 7 X 14 mm dimension (use construction lines to make it simple)
  17. Step 17:
    Create a revolve section as shown below with reference the axis and click OK.
  18. Step 18:
    Create sketch as shown below with specified dimensions at the selected faces and pad backwards with a depth value of 8 mm.
  19. Step 19:
    Pattern the extruded part using Circular pattern taking instances as 4.
  20. Step 20:
    Create the sketches as shown below using 3D project options and using dimension constraints and create pad up to selected edges as show in images.
  21. Step 21:
    Create fillets with specified dimension r = 4 mm as shown below.
    Create fillets at this selected edge with r =1 mm.
    Perform fillet as shown below at the selected edges with radius of 3 mm.
  22. Step 22:
    Create fillets as shown below with specified dimensions on the selected edges with r =2 mm.
    Create fillets r =2.5 mm at the selected edges as shown below.
  23. Step 23:
    Create sketch as shown below and pad to a depth value of 9 mm.
  24. Step 24:
    Create the sketch on the same face which you created sketch in the previous step with specified dimensions and create a pad with depth value of 1 mm.
  25. Step 25:
    Pattern the extruded part using Rectangular pattern taking instances as 4 with a spacing of 3 mm.
  26. Step 26:
    Create Edge fillets on the selected edges with a radius of 2 mm.
  27. Step 27:
    Create a sketch as shown below with the help of 3D projection.
  28. Step 28:
    Create a pad selecting the above sketch up to 9 mm.
  29. Step 29:
    Select the above extruded part and pattern it using a Circular pattern.
  30. Step 30:
    Create fillets as shown below with r =0.3 mm.
    Create another set of fillets at the selected sections as shown below with r =0.5.
  31. Step 31:
    Create a plane as shown below.
  32. Step 32:
    Create a sketch as shown below with the help of projections. Take the width of Rectangle as 2 mm.
  33. Step 33:
    Pad the created sketch in reverse direction with a depth of 12 mm.
  34. Step 34:
    Create fillet for the selected edges with a radius of 0.5 mm.
    Create fillet for the selected edges with a radius of 1 mm.
  35. Step 35:
    Create sketch as shown below with specified dimensions and remove material using pocket option also create circular pattern of the holes.
  36. Step 36:
    Create sketch at the selected faces as shown below.
    Now using Pocket remove material with a depth of 25 mm.
  37. Step 37:
    Pad the selected sketch up to 0.25 mm.
  38. Step 38:
    Create fillet for the selected edges with a radius of 0.3 mm.
  39. Step 39:
    Create a plane at an offset distance of 2 mm as shown below.
  40. Step 40:
    Pad the sketch up to 1 mm downwards and pattern the part using rectangular pattern.
    Mirror the pattern to the opposite side as shown in the figure.
  41. Step 41:
    Create fillets for the extruded parts with r = 0.3 mm.
  42. Step 42:
    Create a sketch as shown below.
    Using Pocket remove material up to 4 mm.
  43. Step 43:
    Create a sketch on the selected face and pocket it using up to last option.
  44. Step 44:
    Create a sketch and pocket the face with a dimension up to 20 mm.
  45. Step 45:
    Create a sketch as shown below, using pocket remove material up to a depth of 9 mm and pattern that using Circular pattern as shown below.
  46. Step 46:
    Create fillets to the patterned holes with a radius of 0.3 mm.
  47. Step 47:
    Create a sketch and Pad it up to 14 mm equally on both sides.
  48. Step 48:
    Create a sketch as shown below and pocket using up to last.
  49. Step 49:
    Create fillets for the selected edges with a radius of 0.3 mm.
  50. Step 50:
    Create a sketch as shown below and pocket it up to 15 mm.
  51. Step 51:
    Create a sketch as shown below using mirror option and remove material using pocket.
  52. Step 52:
    Create a sketch as shown below and pad it up to 7 mm.
  53. Step 53:
    Create fillets for the selected edges with a radius of 0.5 mm.
  54. Step 54:
    The final component looks like this.
