ANY ONE TELL ME ABOUT DRAWING IN CREO
"ANY ONE TELL ME ABOUT DRAWING IN CREO."
    First of all go to File>Prepare>Drawing Properties
    In the drawing properties tab click on change in front of detail options
    In the options ensure that witness_line_intersection value is set to yes
    Now in the drawing click on dimension and in the attach type tab select intersect
  5. Step 5:
    Select both the fillet edges by pressing ctrl
  6. Step 6:
    And also the other two fillet edges again with ctrl pressed
  7. Step 7:
    Now press the middle mouse button to place the dimension and select vertical from dim orient tab
  8. Step 8:
    You will have your dimension
