Autodesk Inventor - How to cut Irregular Helical Groove
See tutorial below
    [1]
    Create 2D sketch:
    - when entering the height: hhh=200 in text box
    - select any dimension > right-click > dimension properties > Document Settings tab: Select "show Expression" in Modeling Dimension Display
    - this is to be able to see which dimension has got what label (name); e.g. dia = d3 & height is hhh [as shown by the red arrows]
    [2]
    Create 3D skecth:
    - helical curve
    - pitch&height
    - "d3" in diameter
    - "hhh" in height
    - "3.142*d3" in pitch (45deg slope = 1 revolution = 1 pitch)
    - rotation direction as required
    - (1) pick bottom point of 2d sketch centerline
    - (2) pick top point of 2d sketch centerline
    - (3)then the end of the base line
    [3]
    Create workplane for swept surface:
    - new workplane
    - pick 3d helix
    - pick endpoint
    [4]
    New 2d sketch:
    - pick workplane
    - right-click > "new sketch"
    - project geometry > point
    - draw horizontal line (line must intersect surface of vase when swept: therefore from centerline out past solid)
  5. Step 5:
    [5]
    Sweep:
    - surface
    - profile
  6. Step 6:
    [6]
    Revolve Solid:
    - revolve
    - pick axis
  7. Step 7:
    [7]
    3d sketch for swept cut:
    - create 3d sketch
    - intersection curve
    - (1) select helical surface
    - (2)(3) select vase (all surfaces)
  8. Step 8:
    [8]
    Switch off unneccesary surfaces/workplanes
  9. Step 9:
    [9]
    Ceate workplane on end of new 3d sketch:
    - new workplane
    - helix
    - endpoint
  10. Step 10:
    [10]
    New sketch to be cut from solid:
    - pick workplane
    - right-click > new sketch
    - project point
    - draw circle
    -finish sketch
  11. Step 11:
    [11]
    Swept cut:
    - (1) sweep
    - (2) cut
    - (3) path
  12. Step 12:
    [12]
    Circular array:
    - (1) Circular
    - (2) select sweep feature
    - (3) Axis > (4) select vase solid
    - (5) 12
  13. Step 13:
    [13]
    Finished product
