Class 1 - Solidworks Simulation - The Analysis Process and Introduction to Finite Element Analysis
see video below
    Hello everyone, welcome to the SolidWorks Simulation training a
    I will be with you during training objective of
    this training and teach how to use solidworks simulation software to analyze
    static structural party behavior and advantages within solidworks we will focus
    on fundamental skills and concepts central to good use of solidworks simulation
    software beauty Let's start then and to begin to understand some basic concepts
    the first tip What is solidworks simulation? Solidworks simulation is a project analysis
    tool based on a numerical technique called finite element analysis
    or faith and this numerical analysis will indicate whether an assembly part or structure will resist the
    loads that are being applied to them beauty we also have a cycle here and in this cycle it shows
    the intention of our Solid Work Simulator it has an intention an objective for us to stop we get
    the best possible prototype The prot ideal type faster so with this dynamic that
    we have all the practical tests 7 that would be carried out Enchantment will be carried out within the
    virtual environment of solidworks beauty people at hand let's continue so he talks a little bit now
    about the evolution of sodium Simões first there in 1982 came Mrs té that was the first simulation software
    because of seeing finite element analysis existing in the market for computers
    then in 1995 1frs make its first main Soccer finite element analysis software in
    the market and with that it becomes partner of solidworks Corporation and from there Cosmos work
    Beleza was born later in 2001 with due worldwide success of Cosmo Words the Systems action which was
    the company responsible for the solidworks Corporation's purchase, also ends up acquiring
    the SRS the company SRS to Aim 2003 the merger of SRS with solidworks Corporation and finally
    they become one and the same thing and there in 2009 we got the rename from Cosmo worx to solidworks simulation good moving
    on a little bit now we're going to talk a little bit about the versions of the
    solidworks simulation first version that we have in the sun and 8 excellent in the standard and in it
    we have tactical analysis for parts and assemblies fatigue analysis solidworks motion also so
    a very interesting software for motion analysis and then we have a single Leader who
    simulated flooring for Fashion that already has other types of analysis within it analysis frequency
    analysis buckling thermal analysis Ah and finally a Solid works in Black champagne E then we have already entered
    the non-linear analysis part and the composite analysis part reminds us here all
    software all higher version case solids pro Fashion it will contain everything that has all kinds
    of tools that have inside the software solid garbage protects no sorry and the solidworks
    simulation stander A software so always the above version will encompass the previous version the same thing as
    the pin Solid Work Simulator a tire will have the Simulator features festoon top Coroner
    beauty good inside teaching speak I use a lot about linear static analysis what it
    encompasses Linear static analysis firstly the results are proportional to the applied loads
    ie if I double mine applied load my result will be reported high and it
    will always keep the aspect ratio if it doesn't keep the aspect ratio then it's no longer running away
    from linear static analysis I'll be entering static analysis not winning as you can
    observe in place too we have a material material and it will always be linearly elastic,
    ie the physical and mechanical properties of the material will change according
    to the loads regardless of the loads received, they will always receive the same material such as
    flow limit it will be fixed beauty and finally the loads all loads are
    static i don't have a shape in a dynamic applied load mind to it, it will always be
    slow and gradual until it reaches its maximum point that's why we don't talk about impact, we do n't
    even talk about Lu, it's good so we can have a small displacement in relation to the size
    of the project, well, you understand a little more about finite element analysis we have a small
    question for you how do you measure distance from your home to another place you want there, well
    we know that it is not simply drawing a straight line from your origin to your destinations as we
