How can I check the angel, radius and depth in catia V5 ?
There is a toolbar called "measure" which can measure all the types of dimensions. you only click on the toolbar and then select the surface to be measured.
first of all click on the toolbar"measure between".
then select the geometry which is to be measured.
for radius select ,measure item
