How do I create a stamped text on autocad?
Hello Anahí Esquivias.
I almost forgot about this. Sorry about the late reply.
I think this should help.
•Enter MTEXT command.
•Type desired text.
•Under EXPRESS TOOLS toolbar select MODIFY TEXT.
•A dropdown option will appear, click EXPLODE and select the text.
•And you will have the outline of the text that you have entered as result.
•I use EXTRUDE and made a 3d of it just to add something.
If this helps, Please don't forget to click upvote / It worked under the my comment(s). Thank
Good Luck :)
•Type desired text. -
•A dropdown option will appear, click EXPLODE and select the text. -
