How do I taper a coil in Inventor?
Tapering a Coil.
    Create a 3d sketch and make a coil
    Create a plane on one end
    Create a sketch on that plane, using the geometry from the coil
    Use the sweep tool with a negative angle.
    It should result in a tip.
  5. Step 5:
    There you have it. Hope it helps.
