How to Change axies in solidwork?
Use the move copy body command. See tutorial below.
-Rohit
Online SolidWorks Training
<a href="http://solidwize.com" onclick="window.open(this.href); return false;">Solidwize</a>
    Go to insert>features?Move/Copy Body, then click on rotate/translate and then from the rotate pulldown you can rotate the body. So for example if I rotate the part shown by the x-axis, by 90 degrees, it essentially moves the front plane to the top plane.
    You may also need to do a second move copy body to translate the body into the right position, so that your shadows are correct.
