How to Convert 12V DC Motor into Low RPM 100Watts Alternator for Wind Energy
Low cost alternator for wind turbine from 12V DC motor.
As we know DC motors can produce electric current when we rotate them but those DC motor needs to be rotated at high rpm (Usually at 1500RPM) to produce 12V electricity so in this video I will show you how you can modify a 12V DC car radiator motor to low RPM (300RPM) DC Generator. I will tell you wire size, number of turns in each coil, connection setting of coils. Each and every thing which is related to DC Generator is described briefly and step by step.
This modified alternator could be used in wind turbines as well as in hydro turbines.
