How to convert enclosed surface to solid in CATIA?
Follow the steps to do the thickness on the surface
Create the piston which you wanted create the thickness
Go to Start -> Mechanical Design -> Wireframe and Surface Design
Select the Offset Tool from the Surfaces Toolbar
Select the surfaces to create a offset surface on the piston surface and enter the required dimension
The surface is created as shown
Likewise the other surfaces are also created by clicking on the surface
Other surface is also created from the given part
Same process is repeated for the other surfaces as below
Other offset surface is created on inside surface
Another surface is selected and click ok to create a offset surface
Step 11:
After that the surfaces looks like this.
Step 12:
Click on all the surfaces and click on Join Tool from the Operations toolbar as shown below
Step 13:
Click on OK for the surfaces to Join
Step 14:
Go to Start -> Mechanical Design -> Part Design
Step 15:
Now click on the Insert on the top and insert a body
Step 16:
Now click on the Thick Surface and select the surface to create a thickness from the surface
Step 17:
Select the direction to which it has to be created and enter the thickness
Step 18:
Now the thickened surface is shown below. And hide the surface if you want to hide it
Step 19:
Apply the material to differentiate that they are different
Step 20:
I have sectioned it to see the difference between the two materials
