how to convert files from MapSource GDB to Autocad DXF
I will give a tutorial in viewing the map in MapSource and convert to autocad ..
    find the map you need, here I am using MapSource ..
    save as to the DXF file extension
    This setting is important ... easy things you can use UTM coordinates ..
    but here I am using "use decimal degrees"
    and klik OK
    then you can open the AutoCAD application, here I am using AutoCAD 2010, and then open - type DXF - I used the "select initial view" - open
  5. Step 5:
    then this screen will appear, select OK
  6. Step 6:
    This is a result that I can and stay in the edit ...
    and the map in autocad I get from MapSource software ..
    I hope this can help ..
