How to create a cube helix
This is a cube helix tutorial
    Create a cube according to picture and extruded it
    Select the front plane
    Draw a vertical line, the same size as the cube from top to bottom
    Select the front plane again
  5. Step 5:
    Draw a horizontal line, starting at the top of the cube (Make this line slightly longer than the cube ’s side)
  6. Step 6:
    Select the sweep surface,and set the horizontal line as the profile, and the vertical line as the path (set option according to picture)
  7. Step 7:
    Select intersection curve (Tools->Sketch tools->Intersection curve) and select the faces according to picture
  8. Step 8:
    Now we can see the intersection curves
  9. Step 9:
    Go to Insert > Reference Geometry > Plane or click at the Plane icon
    Select the Endpoint of the Spline as First Reference
    Select the Spline itself as Second Reference
    Click OK
  10. Step 10:
    Select the new plane in the feature tree and create a sketch according to picture
  11. Step 11:
    Now select the composite curve and select the intersection curve
  12. Step 12:
    Select the circle sketch as the profile, and the 3dsketch as the path (notice to picture)
  13. Step 13:
    Now hide the solid bodies,I hope you’ve learned something about the create a cube helix
