how to create cam follower mechanism
follow the steps as below
Open a new assembly in creo
Create an axis between top and front plane
import the cam part that must have a modle axis and give pin connection
also the cam should have a mid sketch as a path curve
make a new perpendicular axis with the cams axis within the assembly file
select the follower note that it should have a datum point at the end
provide a slot connection between the entire curve on the cam and the datum point on the follower
provide the slider constrain between the perpendicular axis of the cam and the right assembly plane
all done now go for mechanism module from the application menu
select the servo motor and select the motion axis of the cam
Step 11:
go for profile tab and select velocity and give some value for the speed of rotation of the cam
Step 12:
now go for mechanism analysis and provide the time frame
Step 13:
and then select run and have a preview and click ok
Step 14:
now go for playback and select analysis and can see the speed ans then you can capture the video in mpeg format
Step 15:
to start the animation click on play button and you can adjust the speed also
Step 16:
ALL THE BEST
