how to design and analysis t beam welding in ansys?
u can weld through following step in workbench
There are one "WELD" option in geometry. there u can create weld
open geometry
add sketch
made sketch
like this you have two geometry
tool one option is there called weld
select edge and surface and generate
do surface thickness and mesh it
mesh
solve it by applying right click and solve
right click and add deformation and stress and see your answer
