How to design the Tyre and Rim in AutoCAD 2004 ?
This is a tutorial for the model tutorial competiton and its about the design of tyre and rim in the AutoCad 2004
    Start AutoCAD and draw this profile. This will be tyre.
    Now draw the profile of the rim. Be sure to use polyline. If you used arcs and lines then use PEDIT command to join them.
    Draw a Construction line along X-axis.
    Use Revolve command and select the profile for rim.
  5. Step 5:
    Revolve it about x-axis at 360º.
  6. Step 6:
    Now we have the Rim body.
  7. Step 7:
    Again revolve command and select the tyre profile.
  8. Step 8:
    Revolve it by 8º.
  9. Step 9:
    Now enter Rotate3D command.
  10. Step 10:
    Select the tyre part.
  11. Step 11:
    Along X-axis at -4º.
  12. Step 12:
    Now draw these entities along the plane view using pline, pedit, rectangle. Any command.
  13. Step 13:
    Enter Revolve command.
  14. Step 14:
    Select the 2-entities.
  15. Step 15:
    About X-axis at 4º.
  16. Step 16:
    Now enter Subtract command.
  17. Step 17:
    subtract the revolved part from tyre body.
  18. Step 18:
    Revolve again and select the other two plines.
  19. Step 19:
    About X-axis at -4º.
  20. Step 20:
    Subtract them too.
  21. Step 21:
    Enter 3DArray command.
  22. Step 22:
  23. Step 23:
    Polar array type.
  24. Step 24:
    Enter number of items be 45. This will complete the tyre since it was rotated at 8º, 8x45=360º.
  25. Step 25:
    Now we have the Tyre body.
  26. Step 26:
    Plan>>Current View.
  27. Step 27:
    Now we revolve two rectangle about x-axis at 360º.
  28. Step 28:
    Subtract them too.
  29. Step 29:
    Rotate the UCS.
  30. Step 30:
    Plan>>Current view. Now use Cylinder command.
  31. Step 31:
    Construct the cylinder.
  32. Step 32:
    Move it to be symmetrical.
  33. Step 33:
    Use Array command.
  34. Step 34:
    Polar array with 4 items.Subtract them from the rim.
  35. Step 35:
    Now we have the basic body of tyre in AutoCAD 2004 Standard Version.
