How to do a rope using Solidworks 2016
A rope has a slightly more complicated shape than a wire. But you only need to research a little to find a good method. Let's go !
Step 1: Middle body
Make a cylinder with an extruded boss base.
Done !
Step 2: The wire
Select the top face
Make a sketch
Convert the circle
Select Helix and spiral
Go to Swept boss basse
Done !
Step 3: Wire pattern
Select circular pattern of 6 entities.
Step 4: Render
https://grabcad.com/tutorials/how-to-do-great-renders-in-solidworks
