how to give centre line to oblong hole
Heres a Tutorial for you
    After you have sketched your oblong hole start the "Drafting Module"
    Select the "Insert" tab then "Centerline" then "2D Centerline" option
    Change the type to "By Points"
    Select "Arc Center" of first Arc
  5. Step 5:
    Select "Arc Center" of Second Arc
  6. Step 6:
    Change the "Extension" to make centerline pass the arc
  7. Step 7:
    Or "edit" the centerline and move the "handle" manualy
  8. Step 8:
    Complete
