How to loft the edge?
Here you go ...
Open the file, make a new 3D sketch, 2D sketch works too in this case ...
Select the edges you want to loft then click on Convert Entities ...
Your model should look like this; now close the sketch ...
Click on Lofted Surface ...
Select the two sketches either from the model window or feature tree and click the green arrow ...
And you model is finished, it should look similar to this ...
