How to make a Hook Spring in Solid edge - Tutorial.
It is a basic Solidedge tutorial to make a Hook Spring.
This tutorial contains two sessions.
Session 1 : Simple Spring tutorial.
Session 2 : Hook tutorial.
Shortcuts:
CTRL+I - ISO view.
CTRL+H - Sketch view.
Right click - Accept a selection.
Middle click - End command.
F3 - Lock the sketch plane.
Start Solidedge & also open a new ISO part model.
Select front plane & Lock that plane using F3 .
Draw the below Sketch - Circle dia 10 mm & 50mm distance from origin. -
Select Right plane & start a sketch by locking that plane . Draw a vertical line as below with 100mm length.
Select Helix tool from Solids tab -. Sweep group -> Helix.
Select Circle and the line (above 2 sketches) and then right click to accept..
Then give the turns as 4.
Right click. -
Simple Spring is ready.
