How to model a hinge in Solid Edge?
These are the steps..
First of all we create a new part iso.
click on sketch and select top plane, and sketch the following rectange
after you complete the sketch, click ok and select extrude and extrude it 2mm.
Sketch on the top face of the base 3 circles as its showed below.
cut extrude and chamfer of 1mm
create a sketch on the face of the part,
draw a circle and extrude it.
then sketch on the cylinders face and create a circle same as in the previous step and cut extrude it...
Create a pin on the cylinder.
Create a new part and draw the same circles on the base of it (the base is same as in step 2)
Step 11:
Chamfer...
Step 12:
Go to the upper face and sketch a circle and extrude it.
Step 13:
Cut extrude.
Step 14:
Cut extrude the pin hole..
Step 15:
Create a new assembly and join the two parts.
Step 16:
ready
