How to optimize a CAD drawing in AutoCAD
➤How to optimize a CAD drawing in AutoCAD?
If you’ve been working on a file for some time, and you’ve noticed AutoCAD slowing down, then it may be worth doing a bit of a cleanup to help slim that drawing file down.
➤What is an optimized drawing and what are the benefits?
An optimized drawing with a minimum amount of unnecessary data tends to perform faster, the drawing load time is significantly better and chances of drawing corruption also reduce to a great extent.
➤In this video I'll show you the most efficient ways of cleaning and optimizing your drawings in AutoCAD.
➤IT IS GOOD PRACTICE TO OPTIMIZE AND CLEAN YOUR DRAWING BEFORE IMPORTING IT INTO OTHER SOFTWARE LIKE REVIT, 3DS MAX ETC.
➤"Drawing Purge" Add-In download
https://apps.autodesk.com/en/Publisher/PublisherHomepage?ID=200809200135043
