How to remove R symbol in Drafting while giving dimension to fillets
Here is the solution. But you need to run catia as admin. and change your xml file. which one you are using. i show it with ISO. if you need how to run catia as admin. check below.
https://grabcad.com/questions/how-can-create-admin-mode-of-catia
