Hydraulic cylinder help
Under the option Constrain use Type Mate and join two surfaces facing each other (inner bottom of cylinder and piston head) then use options under slide bar called Limits and type the limit dimensions. Minimum is zero position () when the piston is set completely inside of cylinder) and maximum is a stroke of the piston piston.
