I have a problem whit the extrude feature
Here is how you do it.
1. Use sketch 5 to create a split line instead of the curve you created
2. Use surface offset and select the new formed surfaces and the direction
3. Delete the original surfaces.
4. create a 3d sketch and use the edges around the gap
5. Use the 3d sketch to make a boundary surface.
Good luck.
