Noob question: How to model a jagged cone
new tutorial.
    1.create the cone
    2.stop by turning the 2 degrees..middle point,Your cone, will now have a thin slit in it
    3. convert the sheet metal , and now we can use Solidworks to convert the tube into sheet metal. Go to Insert -> Sheet Metal -> Bends and change the radius to the radius of the tube, and K-factor to 1.
    4.
  5. Step 5:
    5.The last thing you need to do is right click on the tube and click Flatten. Your tube should now be flat.
  6. Step 6:
    6.sketch
  7. Step 7:
    7.extrude cut
  8. Step 8:
    8.parts ready
