Parametric Analysis in ANSYS Workbench Using ANSYS Fluent
This tutorial illustrates using an ANSYS Fluent fluid flow system in ANSYS Workbench to set up and
solve simply turbulent fluid flow
Step 1: Prepare geometry for solution
Step 2: Generate volume mesh fpr fluent
Step 3: Set boundary conditions in fluent (symmetry)
Step 4: Set boundary conditions in fluent (inlet with parameterizations)
Step 5: Set boundary conditions in fluent (outlet with output parametring)
Step 6: Set boundary conditions in fluent (wall conditons)
Step 7: Getting first results
Step 8: Start Parametric Analysis
Step 9: Get total results
