Parametric Design in CATIA V5
Hi guys,
I've just launched a new course on PARAMETRIC DESIGN in CATIA.
I know lots of you looking for a complete tutor on this subject for a long time.
Here is the link to my course:
https://www.udemy.com/catia-v5-parametric-design/
It's comprehensive course with multiple examples so if you are interested just give it a try.
  1. Step 1: Some Essential Setups (Important)
    Select these options
  2. Step 2: Creating Parameters
    First you should create your considering parameters
    follow these marks
  3. Step 3: creating parameters
    follow these marks
  4. Step 4: Creating Model
    create your model
  5. Step 5: Edit formula
    In this step you should create a connection between the length you want to control and the parameter you created before. ( this parameter must be length. )
    follow these marks
    as you can see when you create this connection their will be a <<<F(x)>>> sign cross the dimensions.
  6. Step 6: complete your design
  7. Step 7: Edit formula
    As you can see in this step we create a new formula based on other parameter
  8. Step 8: complete your design
  9. Step 9: Edit formula
    Follow the exact same steps to create a connection between the number of holes in this part and the parameter which we crated before. ( this parameter must be integer .)
  10. Step 10: Creating Design Table
    In this step we want to create a connection between our model in catia and a exel table.
  11. Step 11: Creating Design Table
  12. Step 12: Creating Design Table
    In this section you can choose between Various tapes of parameters to join with exel table.
  13. Step 13: Creating Design Table
    In this table you can change features or create new parts
  14. Step 14: Creating Design Table
    As you can see all of those changes will be appeared immediately
  15. Step 15: Creating Design Table
  16. Step 16: Creating Design Table
    you can change all of parameters in this table any time.
  17. Step 17: Some Examples
    you can find a very good example of parametric design in my account.
