PROJETANDO CILINDRO HIDRÁULICO DUPLA AÇÃO
NESSE TUTORIAL, EU VOU MOSTRAR PARA VOCÊ COMO PROJETAR UM CILINDRO HIDRÁULICO DUPLA AÇÃO DO COMEÇO AO FIM. DESENHANDO NO SOLIDWORKS E EXPLICANDO UMA A UMA COMO ELA FUNCIONA E QUAL A SUA FUNÇÃO
TOTALIZANDO 30 VÍDEOS AULAS
Step 1: Resumo do Curso Cilindro Hidráulico Dupla Ação
www.youtube.com/watch?v=NZZYgbmTGQE&feature=youtu.be
Step 2: #01 TIPOS DE CILINDROS HIDRÁULICOS
https://youtu.be/LwDdjZdRTGw
Step 3: #02 AULA DESENHO FUNDO DO CILINDRO HIDRÁULICO
https://youtu.be/GKERuOBStN4
Step 4: #03 DESENHO DA CAMISA CILINDRO HIDRÁULICO
https://youtu.be/Nbj9C92DIeU
Step 5: #04 DESENHO OLHAL DIANTEIRO E TRASEIRO
https://youtu.be/JUOIAOAe_Rs
Step 6: #05 DESENHO DA HASTE CILINDRO HIDRÁULICO DUPLA AÇÃO
https://youtu.be/YMaa3Sr1Itc
Step 7: #06 MONTAGEM DO ENGATE TRASEIRO
https://youtu.be/HViDLXBlxrA
Step 8: #07 MONTAGEM DA HASTE CILINDRO HIDRÁULICO DUPLA AÇÃO
https://youtu.be/a_Gt-DvcuKk
Step 9: #08 MONTAGEM DA CAMISA CILINDRO HIDRÁULICO - PARTE 01
https://youtu.be/Y4yVRen5yc4
Step 10: #09 MONTAGEM DO CANO TLH
https://youtu.be/8AEo2g-0b1w
Step 11: #10 MONTAGEM DA CAMISA CILINDRO HIDRÁULICO - PARTE 02
https://youtu.be/kRvOjTVEIcM
Step 12: #11 DESENHO DO EMBOLO CILINDRO DUPLA AÇÃO
https://youtu.be/g9mBxuxF0kY
Step 13: #12 MONTAGEM DO EMBOLO CILINDRO HIDRÁULICO DUPLA AÇÃO
https://youtu.be/-eieuTPl1_A
Step 14: #13 DESENHO GUIA FRONTAL COM ROSCA
https://youtu.be/VVyoGCmItMM
Step 15: #14 MONTAGEM DA GUIA FRONTAL C/ ROSCA CILINDRO HIDRÁULICO
https://youtu.be/k8ljzDoX36I
Step 16: #15 MONTAGEM DO CILINDRO HIDRÁULICO COMPLETO
https://youtu.be/RUJ0r3MPpnc
Step 17: #16 CRIANDO CONFIGURAÇÃO ABERTO E FECHADO CILINDRO HIDRÁULICO DUPLA AÇÃO
https://youtu.be/FjJE4PtUM2M
Step 18: #17 MONTAGEM FINAL DO CILINDRO HIDRÁULICO DUPLA AÇÃO
https://youtu.be/aqji0UWp6Jw
Step 19: #18 VISTA EXPLODIDA BOOM CILINDRO HIDRÁULICO DUPLA AÇÃO
https://youtu.be/7q7m9pE4GzU
Step 20: #19 ANIMAÇÃO VISTA EXPLODIDA CILINDRO HIDRÁULICO DUPLA AÇÃO
https://youtu.be/zS6piNJ6P3Q
Step 21: #20 FAZENDO ROSCA 3D CILINDRO HIDRÁULICO DUPLA AÇÃO
https://youtu.be/tV4wTUw8asE
Step 22: #21 AJUSTE DO FUNDO COM A CAMISA CILINDRO HIDRÁULICO
https://youtu.be/mpuT0svgHLk
Step 23: #22 AJUSTE DA HASTE COM ÊMBOLO E O ALOJAMENTO ANEL O RING CILINDRO
https://youtu.be/1d9zRuWC6AY
Step 24: #23 AJUSTE CANAL GAXETA NO ÊMBOLO CILINDRO HIDRÁULICO DUPLA AÇÃO
https://youtu.be/DDe6yCipJDE
Step 25: #24 AJUSTE DO ANEL GUIA CILINDRO HIDRÁULICO DE DUPLA AÇÃO
https://youtu.be/AidnbKde91k
Step 26: #25 AJUSTE DO ANEL RASPADOR CILINDRO HIDRÁULICO DUPLA AÇÃO
https://youtu.be/xRqEpArAWpY
Step 27: #26 COMO FAZER UM CILINDRO HIDRÁULICO PARAMETRIZADO NO SOLIDWORKS
https://youtu.be/nWmvJ3pVQko
Step 28: #27 CAMISA ROSCA EXTERNA E GUIA FRONTAL SEM ROSCA CILINDRO HIDRÁULICO DUPLA AÇÃO
https://youtu.be/FUQ1c81w_TM
Step 29: #28 DESENHO DA TAMPA EXTERNA + MONTAGEM NA CAMISA CILINDRO HIDRÁULICO DUPLA AÇÃO
https://youtu.be/mUBYunWlmIc
Step 30: #29 COMO SOLDAR NO SOLIDWORKS CILINDRO HIDRÁULICO DUPLA AÇÃO
https://youtu.be/6mIYukoIlzE
Step 31: #30 PROJETO 3D CILINDRO HIDRÁULICO COMPLETO + BÔNUS
https://youtu.be/RVAvx9Xnpcs
