Tutorial : Creating Sliding Curve Motion in CATIA
Follow the steps to achieve slide curve motion.
Open the SlideCurve_without_kin.CATProduct document.
Select the Slide Curve Joint icon .The Joint Creation: Slide Curve dialog box is displayed
Click New Mechanism.The Mechanism Creation dialog box is displayed:
In our example, keep the default name Mechanism.1. -
Select Curve 1 either in the geometry area or in the specification tree. In our example, select the yellow sphere arc as shown below:
Select Curve 2 either in the geometry area or in the specification tree. In our example, select the line on the green part as shown below:
Click Ok to end the slide curve joint creation.
Now create a second joint (revolute joint) and a third joint (prismatic joint).
Revolute.2:
select line .1 (right white lines)
select line.2 (left white lines)select xy plane ( green) (plane 1)
select xy plane (white lines) (plane2)Select the Angle driven check box in the Joint Creation Dialog Box
when done click OK
Prismatic.3
select line.1
select line.2 as shown below:select xy plane (white lines) (plane 1)
select xy plane (yellow sphere) (plane2)when done click OK
This is what you will obtain.
Step 11:
Click the Fixed Part icon in the Simulation toolbar or select Insert->Fixed Part... from the menu bar.
Click the bottom cuboid for fixed part. (part 4)
Step 12:
The mechanism can be simulated.
Double-click Mechanism.1 in the specification tree.
The Kinematics Simulation - Mechanism 1 dialog box is automatically displayed.
