Tutorial: How to analyze a distributed force in Catia V5 FEM Analysis
Download the file:
Tutorial_FEM_plate.CATPart
    Open the file "Tutorial_FEM_plate.CATPart"
    a material is already given to the part so you can start den analysis
    Open the analysis:
    Start -> analysis & simulation -> generative structural analysis
    choose "static analysis"
    create a "smooth virtual part" on both holes of the plate
    create a "user-defined restraint" on both of the smooth virtual parts as shown in the picture
  5. Step 5:
    create a "surface slider" on the rear edge of the plate
  6. Step 6:
    create a distributed force on the front upper edge of the plate
    500 N in negative z-axis
  7. Step 7:
    doubleclick on "OCTREE Tetrahedron Mesh"
    set size to 4mm
    set absolute sag to 1mm
    make sure element type is "parabolic"
  8. Step 8:
    compute your analysis
  9. Step 9:
    click on "von mises stress" to get your analysis results
    you can also select "displacement"
    or "principal stress" to get a nice view on the compressive/tensile stress
    (especially around the holes)
  10. Step 10:
    thats it
