Tutorial: How to check dimensions and derive ?
This is my entery to Tip and trics challange
    Hello :) so
    1) we have to have an assembley
    2) open it
    3) choose "inspect" (1)
    4) analyze interference (2)
    1) click at "analyze interference" (1)
    2) define first solid/assembley (2)
    3 )click on 1st assembley/solid in model enviroment (3)
    Define second solid/assembley
    2) click on 2nd assembley/solid in model enviroment (2)
    3) then hit ok (3)
    Now we can see where the solid/assembleys are intersecting each other
    1) hit ok (1)
  5. Step 5:
    Now save your assembley
    1) click on "Inventor" button (1)
    2) click on "save as" (2)
    3) click on "save copy as" (3)
  6. Step 6:
    Now create a new .ipt
    1) hit "inventor" button (1)
    2) choose "standart .ipt" (2)
    3) hit create (3)
  7. Step 7:
    In new part
    1) select "manage" (1)
    2) hit "derive" icon (2)
  8. Step 8:
    Select copy of your assembley we created and then
    1) Select red "-" next to every part (1)
    2) Then select the only one we want to create to yeallow "+" (2)
    3) Hit ok (3)
  9. Step 9:
    Now we can see our part derived so there will not be any colisions for 100%.
    But check for error which this procced can create and remove them with standart tools.
    Good luck with proceed and be carefull about the results.Thank u for reading and you can ask me any question :)
