Tutorial - how to design WoodCraft Model example: Dragon
tutorial for this model Dragon WoodCraft
We start of with new part and sketch on the right plane
go to tools - sketch tools - sketch picture
download the pic
Select the pic on sketch picture
position it..
start drawing the contour of the body (middle section)
then on the same sketch start drawing diferent sections,
another few more details...
all the sections I need
then extrude the mid section I used the mid plane in direction to have the model centered..
Step 11:
mid section
Step 12:
I made this section with an offset from the mid section to make my model wider and able to stand correclty
Step 13:
2 sections
Step 14:
3rd section touching the 2nd
Step 15:
legs section
Step 16:
legs added
Step 17:
final section on the right side
Step 18:
right side
Step 19:
Step 20:
2 sections
Step 21:
Step 22:
legs section
Step 23:
legs added
Step 24:
Step 25:
Right side complete
Step 26:
notice the offset
Step 27:
on the left side of we have to start drawing the LEFT side sections it helps to see the picture
Step 28:
all the left sections are drawn on the same sketch
Step 29:
the more asymmetric your model is the better it will look ( at least change the leg positions)
Step 30:
more..
Step 31:
when the left sections are done start extruding
Step 32:
When extruding always check the symmetries of the sections my first sections needs to have an offset!
Step 33:
2nd section left
Step 34:
2section left
Step 35:
legs
Step 36:
legs
Step 37:
last left section
Step 38:
last left section
Step 39:
notice the simmetry (spacing simmetry)
Step 40:
back to the right section sketch and extrude the right section of the face
Step 41:
right side of the face
Step 42:
from the left section sketch extrude the left side of the face
Step 43:
left side of face
Step 44:
on the right side we position the right side fixtures make sure they fit as centered as posible to avoid weak parts
Step 45:
extrude them up to the first left side section (not through it) and offset it outward a bit too
Step 46:
now we have to work on the rear fixture making some cuts to hold the parts in place one to hold the mid section and one to hold the end section
Step 47:
make the fixture nicer by adding some fillets
Step 48:
this hole is made to the end section so that they fit perfectly and this piece holds the rest of the sections in place
Step 49:
then the corresponding hole to the mid section
Step 50:
here you can see the shape of the fixture (it still needs some work to hold the other parts in place)
Step 51:
The front Right fixture is made the same way I made the holes depth half the height of the fixture and made them both exaclty the same to ease the assembly
Step 52:
then we go to the other side.. and position the left side fixtures too, you have to make sure theyre not colliding with the ones from the right side.. then the cutting procedure is pretty much the same as before just sketch over the fixtures face the cut profiles and make sure you are only cutting that part
Step 53:
here is a view of the four fixtures I made them all the same size..
Step 54:
to complete the fixtures we need a spacer so we will just add a little height to the open section its needed only on one side
Step 55:
they end up looking like this
Step 56:
now to fill the hole in the back I sketched on the RIGHTPLANE (symmetry plane), 3 lines then made them equal and made a rectangle over each one of them making sure they touched only on one point
Step 57:
extruded them to fill the hole on a mid plane
Step 58:
then on the same plane sketched a cut section that will be filled by the center section to hold these blocks
Step 59:
extruded the cut on a mid plane
Step 60:
added fillets to each block they have to be on separate fillet features because they are different bodies
Step 61:
Then using Indent Feature with the center section as the target and the bottom of each block as tool we can get a precise fit for each block on the dragons spine!
Step 62:
now back to the hole sketch we use it to extrude the fins to hold the blocks in place
Step 63:
now finally to the face fixture we need to position it and extrude it it doesnt have to have much offset outside the face we will have to work on it to make it look better
Step 64:
a simple way to finish this fixture can be just to make some more spikes come out of it so extruding this profile we can get it done
Step 65:
now I cutted the side face sections to be held bythe fixture
Step 66:
cut extrude the corresponding holes for the fixture to hold the side face sections
Step 67:
made the cut on the mid face section a little higher to make it different from the side ones
Step 68:
then cutted the corresponding piece on the fixture
Step 69:
and thats about it!! =) hope you enjoyed it
Step 70:
after taking those shots I figured it would look better this way...
Step 71:
how about that??
