Tutorial how to engrave a word on a complex surface?
Below i have added pictures of the exact steps you have to do...
First of all we choose a plane...
Then we create a sphere... (the sphere is created as an example in this tutorial. It can be any surface on any part. Steps are the same)
Next we create an offset surface from the sphere outer surface. (notice the offset distance cause we are gonna need it to calculate the depth of the engravement)
Next we create an offset plane, to add a word (this step is optional. I created another plane in order to get better pictures)
Then we create a text...
... and we split-line it on the offset surface we have created. (note. it would be better to hide the solid body while split-line because you may select the surface of the solid body and that is an issue)
After the split-line, we delete all outer surfaces, except of the text we want to engrave.
We thicken all letter-surfaces WITHOUT merging result!
After the previous step, we have 5 solid bodies in our part. We may add them all together, with combine feature...
Like this...
Step 11:
Or we can substract the solid letters, from our main body (sphere) and create a deboss feature...
Step 12:
Like this...
