Tutorial how to make engine part 10
more detailed tutorial -- suite
use extrude command
select shown areas
change the direction with using this button
use offset option
change the offset direction and enter shown value
finally enter this value and confirm that
body is ready
open a sketch on this surface
draw two concentric circles
use cut extrude command like shown.
Step 11:
your body should be like this
Step 12:
now open a sketch on this surface
Step 13:
draw a concentric circle
Step 14:
normal to selected plane
Step 15:
draw a big circle
Step 16:
now we will use this circle option. please click on it
Step 17:
firstly click on this circle
Step 18:
secondly clik on this circle and complate your perimeter circle. If you can not, please try again. you will see it is not too hard
Step 19:
enter the shown dimension
Step 20:
draw a centerline
Step 21:
use trim command
Step 22:
use mirror command and select shown sketch
Step 23:
then select the centerline and confirm that
Step 24:
use trim command again
Step 25:
draw a centerline .
Step 26:
use mirror command and select the sketch
Step 27:
select the centerline that we created just now
Step 28:
draw one more centerline
Step 29:
use mirror command again. select the shown lines
Step 30:
select the shown centerline and confirm that
Step 31:
now use convert entities command and select the shown edges
Step 32:
select the other hole edges and confirm that. sketch finished.
Step 33:
extrude it by 60mm
Step 34:
use linear pattern command and enter shown values
Step 35:
open a sketch on the right plane and draw an axis for linear pattern direction
Step 36:
click on solid bodies and select all bodies
Step 37:
right click and select combine option
Step 38:
confirm that
Step 39:
open a sketc on the shown surface
Step 40:
draw three circles
Step 41:
draw a horizontal axis
Step 42:
Step 43:
use trim command for shown edges
Step 44:
your sketch have to be like this
Step 45:
make same things for the others
Step 46:
select all the inside of the cylinders
Step 47:
then select this area
Step 48:
cut the body by 70 mm
