Tutorial how to make engine part 10
cylinders
more detailed tutorial
open a sketch on the right plane
draw a centerline
use features--referance geometry--plane command
select the line and the right plane
then enter shown value
open a sketch on the plane that we created just now
draw a circle
draw two more circles
draw one more circle
draw a circle like shown
Step 11:
draw a circle again. it should be concentric with the circle that we created just now
Step 12:
now we will use trim command. sketch--trim command
Step 13:
before trim this lines
Step 14:
after trim these lines
Step 15:
finally trim these lines and confirm the command
Step 16:
draw a centerline. we will use it for mirror command
Step 17:
now we will use mirror command. use sketch--mirror commad. then select shown sections
Step 18:
click on this box
Step 19:
select the centerline
Step 20:
confirm that. now we will use trim command again
Step 21:
trim these lines
Step 22:
confirm that. then draw a centerline again. it will uses for mirror
Step 23:
open mirror command and select shown sections
Step 24:
click on shown box, select the mirror axis and confirm that
Step 25:
use trim command and make your sketch like shown
Step 26:
now we will use fillet command
Step 27:
enter shown radius parameter by 15mm, then only click on shown points
Step 28:
confirm that and your sketch should be like this
Step 29:
make same thing for the other points
Step 30:
sketch finished. please check it
Step 31:
now we will extrude this sketch. open extrude command
