Tutorial how to make engine part 3
How to use combine command
Only if you have problem with the combine command, follow this tutorial. if not, go to part 4.
click on the ''solid bodies''. As you see there are six bodies. We will combine them
select all bodies
right click and then select combine command
make ticked the shown area
confirm that. we have one solid body now
