Tutorial: How to make engine part 30
CYLINDER HEADS
make same things for the other side. dont forget the select bigger circles.small ones for the cut-loft command. if your loft be like this, go to top view, drag and drop the green points. make them parallel
place your green points like this
select the centerline
show the sketches
go to right view and open a 3D sketch
draw shown lines they will be used for to create new planes
go to top viev and insert these lines
isometric view of the 3D sketch. please check
use referance geometry--plane command. click on shown lines and confirm that
use same command again and create a new plane like shown
Step 11:
open a sketch on the plane 3
Step 12:
draw a circle like shown. it have to be coincident with shown circle
Step 13:
extrude it by 50mm
Step 14:
open a sketch on the plane 4
Step 15:
draw a circle like before
Step 16:
extrude it 50mm
Step 17:
open a sketch on the blue surface
Step 18:
draw a 4mm radiused circle
Step 19:
use cut extrude command like shown
Step 20:
go to other side, open a sketch and draw a circle again
Step 21:
use cut extrude command again like shown
Step 22:
Step 23:
Step 24:
show the sketches
Step 25:
Step 26:
Step 27:
Step 28:
Step 29:
Step 30:
Step 31:
Step 32:
Step 33:
extrude it by 50mm
Step 34:
Step 35:
Step 36:
extrude it 50mm
Step 37:
Step 38:
Step 39:
Step 40:
Step 41:
next: http://grabcad.com/questions/tutorial-how-to-make-engine-part-31
