Tutorial: How to make engine part 31
CYLINDER HEADS
open a sketch on this surface
draw a circle (2,5mm radiused)
use cut extrude command
make same things for the other side
use mirror command and select the right plane for mirror face
click on the shown surfaces
open a sketch on the shown surface
draw shown sketch
use extrude command like shown
open a sketch on the same surface
Step 11:
draw shown sketch
Step 12:
use extrude command again
Step 13:
Step 14:
draw a circle
Step 15:
draw two centerline for mirroring
Step 16:
use mirror command
Step 17:
use mirror command again
Step 18:
extrude it by 50mm
Step 19:
Step 20:
draw four circles
Step 21:
next: http://grabcad.com/questions/tutorial-how-to-make-engine-part-32
