Tutorial: How to make engine part 39
Cylinder head right side
open the cylinder head that you modelled before
select the bodies and use combine command
open mirror command. use front plane for mirroring.
select the body
untick the merge solids box and confirm that
hide the combine1 body
use save as command and save "Cylinder head right"
next: http://grabcad.com/questions/tutorial-how-to-make-engine-part-40
