Tutorial how to make engine part 7
PISTON
file: piston
    we will model a piston. try to draw a sketch like in the picture. most importand dimension is piston radius.
    use cut revolve command
    open a sketch on front plane and draw a rectangle
    use cut extrude command and cut the body
  5. Step 5:
    open a sketch on this surface
  6. Step 6:
    draw this sketch with using mirror command
  7. Step 7:
    extrude it 40mm. then open a sketch on this surface
  8. Step 8:
    use convert entities command and select this surface
  9. Step 9:
    draw the shown sketch
  10. Step 10:
    use trim command
  11. Step 11:
    extrude 10mm and mirror it
  12. Step 12:
    open a sketch on blue surface and draw a 11mm circle center of it
  13. Step 13:
    cut the body
  14. Step 14:
    now you should use fillet command.
  15. Step 15:
    use dome command
  16. Step 16:
    piston is ready for now. follow next tutorial
