Tutorial how to twist body in SW
here a tutorial about flex command
you can make your own fan wing
please click on it worked if you liked
insert>>features>>flex
select body and you can use this 4 options
at first option you can bend the body -
this option twists the body
tapering..
stretching
and if you want to make a wing, you must to use tapering and then twisting
all done:))
