Tutorial: how to use the file format. jpg eg for format CAD in the T-FLEX Parametric CAD?
You can do it on any wall model
or the active surfaces
1) insert the image. Jpg to the active work plane
(wall / surface work / surface of a cylinder or sphere)
Now the best in the filter selection
deactivate the filter "images" and set this image level -1 in the properties -
2) turn on the option sketchbook
and using a variety of available options (lines, rays, splain) we outline the necessary fields -
3) we are ready 3D profile
-select it and copy (right mouse button) -
4) paste in our file (right-click) in the model window
use the option "transformation" to set our profile
against the wall important to us
use the scaled to the required size -
5) of the "wall"
Select "imprinting" (throw, projection)
acceptance when readyIt is 3D ready profill
on the wall where you need it
to create a 3D geometry
Next photos show different results
on different walls -
6)
7)
8)
9)
thank you
