TUTORIAL: Write down the unit " cm3 " in solidworks
how to do it in solidworks ..?
I will give you the tutorial ..
    have you ever experienced anything like this ..?
    while you want like this ..
    enter into the drawing in solidworks, write the data, and at the command "Formatting"
    select "Stack"
    Then in the Stack Note you can choose
    - Style: Without select line
    - Alignment: select Upper portion of stacked text
    - Stack Size: select 60%
    - Stack: Upper = 3
    and then click OK.
    Finish
    Have a nice day
    ^_^
    See you
