How can i check in ansys software at what load a circular beam of radius 3mm and length can be between 280-320mm of stainless steel material breaks....
Beam is fixed at both ends and load is applied perpendicular to the circular surface along the radius......
It is also desired to find out the amount of permanent deformation occur in the beam before breakdown.
