Help me to design infinity eight.
Accepted answer
1 Other answer
Step 1: Make an "O" shape in a plane (let's say XY). Then pad it to create 3D figure.
Step 2: Chose a perpendicular plane (let's say XZ) and make the same "O" again. Create it's 3D figure.
NOTE: Make sure that the inner circumference of first design coincide with the outer circumference of other design.
Step 3: Use fillet to smoothen the edges along the circumference. Add colour as per your need.
I hope you shall have the desired result.
Thank you! Best wishes!
