Two Piece handlebar and Triple Tree
I need to design a Two-Piece Handlebar and Triple tree. What are the ways I can make the ergonomics more better for the overall handling. I have designed a Triple Tree in solidworks but what are the ways I can make it more practical and implementable. Can you look after It can suggest me if I can improve on it or if I need to make the new one what are the ways I should move forward. How can I made necessary modifications to it for making it possible to add two piece handlebar. Also what are the possible ways I can carry various analysis on it.
Thank you for your help and assit.
Check out some of these designs as well :
https://www.justpanhead.com/product-category/harley-davidson-parts/handlebar-control/page/59/
The strap area seems a bit thin. Keep in mind that area is both a clap and rigid part of the suspension. I would the large radius larger and a filet at the intersection of elements. If you have FEA available you should analyze.
I found this case study for you in case it helps :
https://www.raceenginesuppliers.com/Suppliers/case-study-top-triple-tree
